JanneI
Check Box to toggle jitter on/off on Graph Builder
I would like to have a check box object on top of Graph builder view to toggle on/off separation of overlapping points (jitter). I know that this can be done from control panel but from visualization perspective, I want to keep the control panel closed.
Example script below which creates control elements for jitter on top of graph. Despite of my best efforts, I can't get the check box to toggle the jitter; I don't know what is the correct way to send update to report.
I am requesting Your help with the syntax.
dt= Open("$SAMPLE_DATA/Big Class.jmp");
gb=Graph Builder(
	Show Control Panel( 0 ),
	Variables( X( :height ), Y( :weight ) ),
	Elements(
		Points( X, Y )
jitter = 1;
jitter_elements=H List Box(
		cb=Check Box(
			{"Jitter enabled"},
			If(cb<<Get()==1,
				gb << SendToReport(Elements(Points(Jitter( "Positive Grid" ), Jitter Limit( jitter )))), // This is not correct but something like this (maybe)
				gb << SendToReport(Elements(Points(Jitter( "None" ))))									 // This is not correct but something like this (maybe)
		sb = Slider Box( 0, 2, jitter,
			neb << set( jitter );
		neb = Number Edit Box(jitter,
			<<setfunction(
				Function( {this},
					jitter = this << get;
					sb << inval;
rgb = Report(gb);
(( rgb[PictureBox(1)] << Parent ) << Child ) << Sib Append (jitter_elements);
Re: Check Box to toggle jitter on/off on Graph Builder
Manipulating Elements is a mess to my knowledge and it gets even messier when you have grouping. That's why I try to (usually) avoid it and just redo the graph. Here is one way you could try using Update Elements to change Jitter
jitter = 1;
New Window("",
	V List Box(
		H List Box(
			cb = Check Box(
				{"Jitter enabled"},
				If(cb << Get() == 1,
					Report(gb)[GraphBuilderBox(1)] << Update Element(1, 1, 1, {Type("Points"), X, Y, Legend(3), Jitter("Positive Grid"), Jitter Limit(jitter)});
					Report(gb)[GraphBuilderBox(1)] << Update Element(1, 1, 1, {Type("Points"), X, Y, Legend(3), Jitter("None")});
			sb = Slider Box(0, 2, jitter, neb << set(jitter)),
				jitter,
				<<setfunction(
					Function({this},
						sb << inval;
		gb = dt << Graph Builder(Show Control Panel(1), Variables(X(:height), Y(:weight)), Elements(Points(X, Y)));
Other useful functions might be Add Elements and Remove Elements, also see this post Updating the Graph Builder's Element statement
Craige_Hales
Nice idea, not obvious how to do it, looking forward to an answer.
Craige
jitter = 1;
New Window("",
	V List Box(
		H List Box(
			cb = Check Box(
				{"Jitter enabled"},
				jitter,
				<<setfunction(
					Function({this},
						sb << inval;
JanneI
Thanks Jarmo,
Your solution (Update elements) works well, very good.
Below is further modified version to get also the slider and number boxes updating the graph.
jitter = 0.2;
New Window("",
	V List Box(
		H List Box(
			cb = Check Box(
				{"Jitter enabled"},
			sb = Slider Box(0.1, 0.2, jitter,
					neb << set(jitter);
				jitter,
				<<setfunction(
					Function({this},
						if(jitter<0.1, jitter=0.1,  jitter>0.2, jitter=0.2);
						sb << inval;
						neb << set(jitter);
		gb = dt << Graph Builder(Show Control Panel(0), Variables(X(:height), Y(:weight)), Elements(Points(X, Y)));
