BookmarkSubscribe
miguello
Community Trekker
Changing titles for Variability Charts with ByGroups using JSL
I have a script that plots Variability Chart by some group.
rep=Variability Chart(
    Y( :Name( "MyY" ) ),
    X(
          :Name("MyX1"),
          :Name( "MyX2" )
    Analysis Type( Name( "Choose best analysis (EMS REML Bayesian)" ) ),
    By (:Name("ByGroup")));
Then I'm getting a plot for each ByGroup with two bars: "Variability Gauge ByGroup=group1" and "Variability Chart for MyY".
I found how to change the title of the second one to  just "MyY". But I cannot find hot to change title of the first one to only reflect ByGroup.
I can refer it one by one, if I know all the ByGroups, explicitly, but I don't want to hardcode all the ByGroups.
I was hoping for something like wildcarding and replacing title like this:
           Dispatch(
                "Variability Gauge ByGroup=?",
                OutlineBox,
                {Set Title( :Name("ByGroup") )}
But it's not working. Any ideas how to make it work?
Re: Changing titles for plots
I believe the issue you are having is that each By Group is handled as a separate tree structure under report(rep).  Therefore, for each of the By Groups, you have an Outline Box(1) and an Outline Box(2).
To change the title of the outline box for the title Variability Gauge ByGroups and the Variability Chart for MyY titles  you can do it with the following
rep = Variability Chart(
       X( :Name( "MyX1" ), :Name( "MyX2" ) ) ,
       By( :Name( "ByGroup" ) )
Report( rep[1] )[Outline Box( 1 )] << set title( "The By line for group 1" );
Report( rep[1] )[Outline Box( 2 )] << set title( "The Variability Chart title for group 1" );
Report( rep[2] )[Outline Box( 1 )] << set title( "The By line for group 2" );
Report( rep[2] )[Outline Box( 2 )] << set title( "The Variability Chart title for group 2" );
Miguello,
When I've done this I've used and expression with a string.  Build the string with the grouping name, substitute into the expression, then evaluate the expression.  There might be another way to do this, but that way has consistently worked for me in the past.
Mest,
M
