Jaz
Jaz
Level V
Changing Column Data Types
I wanted to change my column data types to continuous and numeric but the following is giving me a scriptable[] error, I'm not sure what that means.
Column(dt, 1) << Data Type( Numeric ); Column(dt, 1) << Set Modeling Type (Conitnuous);
So, I used this next line of code:
dt:Column(1) << Data Type( Numeric );
dt:Column(1) << Set Modeling Type( Continuous );
But it still doesn't like it.
Any suggestions would be appreciated.
Re: Changing Column Data Types
n your first example, the word Continuous is spelled incorrectly.
In the second example, the reference to your column is incorrect.  It should be:
Column(dt,1) << Data Type( Numeric );
Column(dt,1) << Set Modeling Type( Continuous );
or it could be collapsed into one statement
Column(dt,1) << Data Type( Numeric ) << Set Modeling Type( Continuous );
Jaz
Jaz
Level V
Thanks.
