michaelh
Change to cross correlation JMP17
Hi all,
I recently updated to JMP17.0.0, and there is a change/problem with Time Series analysis. I am using a by variable to run time series analysis on multiple samples. The goal is to cross-correlate one time variable with 2 others (say, A v B and A v C). I specify two time series (B and C) and one input list (A) with my by variable, and the usual time series report comes up, and I can produce the individual cross-correlation tables as usual. However, if I right-click to save the cross-correlations to a combined data table for further analysis, it no longer distinguishes between B and C. There used to be 2 colums, one that was AxB and one that was AxC. Now there is one column and no variable that distinguishes B and C correlation values.
Am I missing something?
Thanks!
Michael
Re: Change to cross correlation JMP17
If I created the report correctly the same issue is still present in JMP17.2. I suggest you contact JMP support about this.
