rahulsmils
Change thickness of box plots on variability chart
Hi all,
I am creating a  variability chart in jmp. The box plot lines look too thin and vanishes amongst markers.
Is there an option to change all the box plot line width at once for the entire figure?
I know I can individually change each box plot by right-clicking each of them separately, but this process becomes tedious for multiple box plots.
Can I use that in form of jsl code?
Thanks a lot !
gzmorgan0
Re: Change thickness of box plots on variability chart
Boxplots on the variability chart are BoxPlotSeg.  This script demonstrates some of the modifications you can make to a BoxPlot Seg. You can cahnge the line width but I do not see a message to change the box width.
dt = Open(
	"$SAMPLE_DATA/Variability Data/2 Factors Crossed.jmp"
vc = dt << Variability Chart(
	Y( :Measurement ),
	X( :Operator, :part# ),
	Show Box Plots(1)
_xbp = vc <<Xpath("//BoxPlotSeg");
_xbp << set box style("Solid");
_xbp << set box type("Outlier");
_xbp << set fill color ({0,0,221});
_xbp << set transparency(0.3);
_xbp << set line color({0,0,128});
_xbp << set line width(6);
gzmorgan0
dt = Open(
	Y( :Measurement ),
	Show Box Plots(1)
