OneNorthJMP
Level V
Change group column name
JMP has the feature to group some parameters into a group. But it automatically take the 1st params into group column name. HOw do i change the group column name in JMP after grouping?
OneNorthJMP
Level V
Re: Change group column name
Oh I got it now. I need to close the break down and only then i can double click and change the column name.
OneNorthJMP
Level V
ce-line
I know this was posted almost three years ago but I appreciate you replying to yourself with the solution!
