DMW
DMW
Change default setting for scale format in graph builder
Ive been using JMP on the Mac for a few years and now have to us the PC version (JMP® 16.1.0 (539038)
Microsoft Windows 10 Pro 64-bit (10.0.19042.0).   I use graph builder a lot and find that the axis (either) "scale format" defaults to "fixed decimal" which does wacky things when trying to use certain increments for the scale.
This is with the X axis set at increment of 0.05 with fixed decimal
This is with "best fit" same increment.
Never seen this on my Mac, and I'm not able to compare this data on there as I only have one seat for JMP and it's on the PC now.  Any notions?
Thanks,
Diane
  If I change this to "best fit" I don't seem to have this issue.  Is there a way in the preferences to set this to best fit?
Thanks
0 REPLIES 0
