UserID16644
Level V
Change column format
Hi all,
I am opening a csv file with dates (0000-00-00) having a default column data type character. However, whenever I tried to update the column with a formula from another column with a date value, I cannot change the format into date. My code looks something like this
dt = Open ("C:\Users\table1.jmp");
dt2 = Open ("C:\Users\table1.jmp");
dt2 << Update( With( dt),
	Match Columns( :idFin = :idFin ),
	Add Columns from Update Table( :Start_Date, :End_Date )
dt2:Name ("Actual Start Date") << Data Type( Numeric,  Format( "y/m/d", 19 ));
dt2:Name ("Actual Start Date") << Set Formula( :Start_Date );
After having the formula (:Start_Date) on my Actual Start Date column, it doesn't change to y/m/d format but instead it has the Best format. Please help
Re: Change column format
A few issues
  1. You can not reset the Datatype etc. when the column is has a formula that sets the value for the column.
  2. I don't understand what the purpose of running the Update Platform when it was updating a data table with the same data table.
  3. I don't understand what dt9090 is.
  4. You need to create the column using the formula you specified(and then remove the formula) before changing the data type and format.
Below is a much simplified script that creates a simple example data table that has your indicated original date structure, and then adds a new column.  It then deletes te formula and then changes the data type and sets the new format.
names default to here( 1 );
dt = New Table( "Example",
	New Column( "Start_Date", character, set values( {"2023-03-22", "2022-12-04"} ) )
dt << New Column( "Actual Start Date", character, Formula( :Start_Date ) );
dt:Actual Start Date << delete formula;
dt:Actual Start Date << Data Type( Numeric ) << modeling type( continuous );
dt:Actual Start Date << Format( "yyyy-mm-dd", 19 );
A few issues
