UserID16644
Level V
Adding dates from columns
I have 3 dates that I wanted to add up in order to calculate the total number of days. Is there a way to do this? I just know the Date Difference ( ) function, but doesn't know if there is a function used in calculating the sum of dates from three different columns?
Jeff_Perkinson
Re: Adding dates from columns
Adding dates is an interesting concept.
Can you explain exactly what you mean?
I’m trying to guess what April 3, 2022 + May 22, 2022 would be.
-Jeff
UserID16644
Level V
Yes, so the sum would be how many days does April 3-May 22 have
Here is a simple example:
date1 = informat("4/3/2023");
date2 = informat("5/22/2023");
Date Difference(
	Date1,
	Date2,
	"Day",
	"start"
Jeff_Perkinson
That helps. The Date Difference() function will tell you the number of days between two dates.
start = 03Apr2022;
end = 22May2022;
days = Date Difference( start, end, "Day" );
49
You said something about a third date. How will that be used?
For more information you might find Using dates, times, datetimes and durations in JMP useful.
-Jeff
