Yngeinstn
Level V
Change Values in a Column
I found a script that works well however the time it takes to parse at minimum of 80,000 rows is quite long. This is only 1 wafers worth of data and there is an option to add an entire lot ( 7 more wafers). Which the time it takes to change the values will increase by a lot.
Any suggestions?
Thank you
	r = dt <<  Get Rows Where( :testname == "test1" );
	Column( dt, "channel" )[r] = "N/A (test1)";
	s = dt <<  Get Rows Where( :testname == "test1" );
	Column( dt, "mode" )[s] = "N/A (test1)";
	t = dt <<  Get Rows Where( :testname == "test2" );
	Column( dt, "mode" )[t] = "N/A (test2)";
Yngeinstn
Level V
Re: Change Values in a Column
uday_guntupalli
Level VIII
@Yngeinstn ,
	// Alternative Approach
	dt[r,"channel"] = "N/A (test1)";
	dt[s,"mode"] = "N/A (test1)";
	dt[t,"mode"] = "N/A (test2)";
Best
Uday
gzmorgan0
As written r and s should be the same rows. Get r , the index of rows where :testname == "test1", and use it for both columns channel and mode.
Also if using JMP13 or later, this syntax could save time.
dt[r,{"channel","mode"}] = "N/A (test1)";
Yngeinstn
Level V
Thank you for the quick response. I will try this asap.
Yngeinstn
Level V
Thank you
