HansD
Change Label for Missing in Tabluate
I'm using Tabulate with the 'include missing for grouping column' - I would like to change the label for the word Missing in the table
Thierry_S
Re: Change Label for Missing in Tabluate
A quick workaround would be to save the Tabulate output as a table (Main Platform Menu: Red Triangle Top Left > Make Into a Table) and change the column header there. However, if you need to work with the output itself, you will need to look deep into the Tree Structure of the output to figure out if the Column labels can me edited (from a quick check, it does not seem to be editable but I'll leave other to comment)
Best,
TS
Thierry R. Sornasse
HansD
Hi Thierry,
Thanks for your response - your solution will give an solution.  I would not like to take this route for this specific application
Hans
The work around that I would do, is to replace the missing cells with the value you want to be displayed, thus changing the missing value to a specified value.
for each row(
     If(:sex ==  "", :sex = "my new group"
HansD
Hi Jim,
Most probably the easiest solution - I hoped there was a feature in JMP I didn't see.
Hans
