matth1
Change Graph Builder line widths with overlay variable
I want to be able to change line widths in Graph Builder when I have an overlay variable specified but I don’t know upfront what the values of that variable might be (or how many values there may be). I’ve tried the following based on a community post:
Open("$SAMPLE_DATA/Big Class.jmp");
gb = Graph Builder(
      Size( 534, 454 ),
      Show Control Panel( 0 ),
      Variables( X( :height ), Y( :weight ), Overlay( :sex ) ),
      Elements( Points( X, Y, Legend( 3 ) ), Line( X, Y, Legend( 5 ) ) )
fbs = gb << XPath("//FrameBox");
For(i = 1, i <= N Items(fbs), i++,
      frame = fbs[i];
      seg = (frame << Find Seg("Line Seg"));
      seg << Set Line Width(1);
But this only changes the thickness of one of the lines (in this case, for :sex=="F").
Thanks!
Re: Change Graph Builder line widths with overlay variable
Hi Matthew,
The simple fix is to simply change Find Seg into Find Segs. This will find all the line segments (there are two, one for each sex) and replace the width to what you need.
Furthermore, because there’s only 1 frame box (or 1 graph), we do not need the For loop here. I found the community post you were referring to, and in that example, there are two frame boxes.
So we can simplify your code as follows:
gb = Graph Builder(
      Size( 534, 454 ),
      seg = (fbs << Find Segs("Line Seg"));
Hope this helps!
Hi Matthew,
gb = Graph Builder(
      Size( 534, 454 ),
Hope this helps!
hogi
Level XIII
Find Segs
such a useful function! is there any documentation?
