ComplexNerd
Change Filter Col Selecter Application Builder with datatable
Hello guys..
I am working on application builder., In the interface i have a col Filter box for with now when application opens it prompts to select datatable. Now i have a list box in which it display all the open datatables, when users selects a datatable and clicks the button i want the columns in col filter box to change accordingly. I tried set datatable, and also equating the underlying datatable1 to the selected one. It dosent work. Can i please get some guidelines how to perform this.
Thanks in advance
Re: Change Filter Col Selecter Application Builder with datatable
I think generally you will have to re-create the filter col selector if you want to change the data table which it is related to. I don't use Application Builder so here is example how it could look like (in very simple case) as JMP script
nw = New Window("Filter Col Selector Example",
	fcs_collector = V List Box(
		vlb = V List Box(
			fcs = Filter Col Selector(dt)
wait(1);
dt2 = Open("$SAMPLE_DATA/Probe.jmp");
vlb << Delete Box;
fcs_collector << Append(vlb = V List Box(
	fcs = Filter Col Selector(dt2)
