tnorthen
Change Display of Values for Sharing
Hello Everybody,
My peers and I will be sharing some of our work soon. We want to be able to share this work without giving out key parameters that were used for IP purposes. I remember seeing in the JMP courses that we can use -1, 0, 1 etc in place of some of the actual values. But I can't find it in the JMP help or online. Is there a function that can automatically do it for us? If not, how would I do it manually?
Thanks for the help
Re: Change Display of Values for Sharing
Select the data column. Select Cols > Recode. See help here.
Georg
Maybe you want to use "anonymize", see Screenshot, to change identifiers.
And you can use Transformations (right click on column, new formula column etc.) to generate values between 0 and 1 etc.
Please refer to help also.
Anonymize Data (jmp.com)
Georg
