Categorical Factor, Controlling probability by script
I am tring to make automation code to control the nominal values by the script.
For the simulator, I want to set the probability of the values. However, it doesnt seem to work.
How can I control categorized values probability with the script ?
prf = Profiler(
    Y( :Pred Formula Eye Height, :Pred Formula Eye Width ),
    Profiler(
        1,
        Term Value(
            Duty Cycle(0.48, Lock( 0 ), Show( 1 )),
			Random Jitter(0.04, Lock( 0 ), Show( 1 )),
			Deterministic Jitter(0, Lock( 0 ), Show( 1 )),
			Process Variation("Normal", Lock( 0 ), Show( 1 )),
			Temperature(11.25, Lock( 0 ), Show( 1 )),
			Voltage(1.0, Lock( 0 ), Show( 1 ))
        Simulator(
            1,
            Factors(
                Duty Cycle << Random( Normal( 0.48, 0.08 ) ),
				Random Jitter << Random( Normal( 0.04, 0.05 ) ),
				Deterministic Jitter << Random( Normal( 0, 0 ) ),
				Process Variation << Distribution( {"Fast", "Slow", "Normal"}, [0.33, 0.33, 0.34] ),
				Temperature << Random( Normal( 11.25, 2 ) ),
				Voltage << Random( Normal( 1.0, 0.05 ) )
            Responses(
                Pred Formula Eye Height << No Noise,
				Pred Formula Eye Width << No Noise
Re: Categorical Factor, Controlling probability by script
Could the issue be that you have Profiler twice? This is an example from Scripting Index which seems to send the Simulator after Profiler has been created
dt = Open("$SAMPLE_DATA/Tiretread.jmp");
obj = Profiler(
	Y(
		:Pred Formula ABRASION, :Pred Formula MODULUS, :Pred Formula ELONG,
		:Pred Formula HARDNESS
obj << Simulator(
	1,
	Factors(
		SILICA << Random(Normal(1.25, 0.3266)),
		SILANE << Random(Normal weighted(50, 6.532)), SULFUR << Fixed(2.25)
	Responses(
		Pred Formula ABRASION << No Noise, Pred Formula MODULUS << No Noise,
		Pred Formula ELONG << No Noise, Pred Formula HARDNESS << No Noise
But I would guess you could just move it inside the Profiler message
obj = Profiler(
	Y(
	Term Value(
		SILICA(1.75, Lock(0), Show(1)),
		SILANE(45.2, Lock(0), Show(1)),
		SULFUR(2.45, Lock(0), Show(1))
	Simulator(
		1,
		Factors(
		Responses(
Hi thanks for the fast reply.
I was curious how I could control the probability of factor Process variation.
this have 3 discrete value fast, normal, slow.
I want to simulate it with specific probability with script.
however with below syntax. It does not work.
Can I Get help for the right syntax? I cannot find any regarding function for it
Have you done it in JMP interface and then saved the script? It should have the correct syntax for you to use
