Hegedus
Case Insensitive searches
Most JMP is case insensitive except when it comes to text values.
Since text data is often messy and case is one way it shows up, is there a way to do case insensitive  versions of Contains?
Craige_Hales
Re: Case Insensitive searches
regex is case sensitive by default,  PatMatch is insensitive by default.
regex("The Quick Brown Fox", "quick", "\0", IGNORECASE);
"Quick"
regex("The Quick Brown Fox", "quick", "\0");
returns missing
rc = PatMatch("The Quick Brown Fox", patPos()>>where + "quick">>what);
show(rc,where,what);
rc = 1;
where = 4;
what = "Quick";
PatMatch("The Quick Brown Fox", patPos()>>where + "quick">>what, NULL, MATCHCASE);
returns 0
Regex
Craige
If you want to specifically use Contains(), you can use Lowercase() or Uppercase() to perform case-insensitive searches:
str1 = "Hello";
str2 = "ELL";
Contains( Lowercase(str1), Lowercase(str2) );
Contains( Lowercase(str1), "ell" );
Contains( Lowercase(str1), Lowercase("Ell") );
Craige_Hales
"Quick"
returns missing
rc = 1;
where = 4;
what = "Quick";
returns 0
Regex
Craige
str1 = "Hello";
str2 = "ELL";
tim_reeves
this was helpful to me and I think it should be mentioned in the Help for the Contains function, which does not even mention that the function is case-sensitive.
Craige_Hales
more information on case and regex: Back Reference
Craige
ErraticAttack
If you're trying to find a matching item in a list of strings (say column titles) and you want to match JMP's default of ignoring case / spaces, you can use the As Name function, see below
Names Default to Here( 1 );
list = {"Height", "Weight", "CamelCase", "__Dunder_Mifflin__" };
Show( Contains( list, "camel case" ) ); // 0
named list = {};
For( i = 1, i <= N Items( list ), i++,
	named list[i] = As Name( list[i] )
Show( Contains( named list, As Name( "camel case" ) ) ); // 3
Jordan
