If you double click on one of the values in the Cpk column of the report, you will see the format information for that table's column. By default, in the Capability Report, the Conditional Highlighting is set to "Capability Index". This defines the default colorization. If you click on the down arrow you will see that you can add your own Highlighting specification.
![txnelson_0-1679489758981.png txnelson_0-1679489758981.png](https://community.jmp.com/t5/image/serverpage/image-id/51379iBA9CD672CC33B49E/image-size/medium?v=v2&px=400)
While this approach will work, @Mark_Bailey approach is a better approach
