ACraig
Can you use JSL script to run the Means/ANOVA and Student's t within Fit Y by X
I am building a workflow and while recording I do the Fit Y by X and then do the Means/ANOVA and Means Comparisons -> Student's t. When I stop recording it only does the JSL script for the Fit X by Y:
Data Table( "My Table" )
 << Oneway(
	Y( :Percent Change ),
	X( :Estimate ),
	Means( 1 ),
	Mean Diamonds( 1 ),
	Each Pair( 1 ),
		Dispatch( {}, "Oneway Plot", FrameBox, {Frame Size( 474, 336 )} )
Does anyone know how to add the code in to have the Means/ANOVA and Student's t run auotmatically?
Re: Can you use JSL script to run the Means/ANOVA and Student's t within Fit Y by X
Doesn't that script include all of those (Means(1) and Each Pair(1))?
ACraig
I don't quite understand what you mean.
I assume when you are recording the workflow, you will also select correct things from fit y by x platform? So you select Means
and means comparison
So you get report like this
when you close the report it should be recorded
Other option is to Save Script to Workflow (this way you don't have to close the report window)
