lala
Level IX
Can this formula be completed in one step?
I tried, but failed
Thanks Experts!
ca = "A";New Column( ca );
Column( ca ) << Formula( height / Lag( height, 5 ) > 1.1 );
dt << run formulas;
Column( ca ) << deleteFormula;
ca = "SumA";New Column( ca );
Column( ca ) << Formula( Sum( A[Index( Row() - 9, Row() )] ) );
dt << run formulas;
ca = "Sum1";New Column( ca );
Column( ca ) << Formula( Sum( height[Index( Row() - 9, Row() )] / height[Index( Row() - 9 - 5, Row() - 5 )] > 1.1 ) );
dt << run formulas;
Column( ca ) << deleteFormula;//??
lala
Level IX
Re: Can this formula be completed in one step?
What is the formula supposed to do and is there a specific reason to try and force it to be a single step?
Here is one way to do it
ca = "A";
New Column( ca, set each value( :height / Lag( :height, 5 ) > 1.1 ) );
ca = "SumA";
New Column( ca, set each value( Sum( :A[Index( Row() - 9, Row() )] ) ) );
ca = "Sum1";
New Column( ca,
	set each value(
		As Constant(
			a = [];
			For( i = 1, i <= N Rows( Current Data Table() ), i++,
				If( i > 5,
					a = a || ((:height[i] / :height[i - 5]) > 1.1),
					a = a || .
		If( Row() > 5,
			Sum( A[Index( Max(6,Row() - 9), Row() )], . )
 Here is another way
ca = "Sum1a";
New Column( ca,
	set each value(
		If( Row() <= 5,
			val = .,
			theRows = Index( Max( 6, Row() - 9 ), Row() );
			val = .;
			For Each( {calc}, theRows,
				val = Sum( val, (:height[calc] / :height[calc - 5]) > 1.1 )
		val;
lala
Level IX
Thank Jim!
OK、
It's a formula I forgot and got in the community before.
Now think of it, it is OK:
Column( ca ) << Formula( Sum( height[Index( Row() - 9, Row() )] :\ height[Index( Row() - 9 - 5, Row() - 5 )] > 1.1 ) );
dt << run formulas;
lala
Level IX
