Can there be multiple classes in a dependent variable to run a decision tree model
We want to run a decision tree model to analyze survey responses and the dependent variable has multiple classes. Is it possible to run an accurate model with this or would the dependent variable have to be a binary classification
Victor_G
Re: Can there be multiple classes in a dependent variable to run a decision tree model
Hi @PartialGopher16,
Welcome in the Community !
If I understand your question well, you would like to analyze survey responses, and each response may have different levels possible ?
Decision Tree are able to do multi-class classification. You can try on sample datasets, like Car Poll.jmp (accessible in "Help", "Sample Index", "Exploratory Modeling"), the response used in the "Partition" (decision tree) script is "Country", which has 3 possible classes : Japanese, European, American.
The Decision Tree will use the other variables to try to predict from which country does each car owner comes from :
I hope I did understand your question and that this response will help you,
Victor GUILLER
Victor_G
Victor GUILLER
Thank you for your response and your help, you have answered my query
