Neo
Neo
Can columns be plotted in graph builder be separated by PAGE using a column name categories?
The script below plots a few columns (multiple parameters on Y axis) with column names starting with P in Graph Builder. I want to simultaneously plot a few other columns which with column names starting with N in the next PAGE (command commented in my script below).
In the next PAGE I would like to plot a few other columns with column names starting with, say  V and so on.
The column category information can come predefined either in a separate data table or in any other form, perhaps a list (I am flexible on that). The question is whether this is doable via JSL and if so how?
Names Default To Here (1);
clear log ();
dt = open( "$SAMPLE_DATA\semiconductor capability.jmp" );
dt << Ungroup Columns();
Graph Builder(Size( 1469, 718 ),
	Variables(X( :lot_id ), Y( :PLG2 ), Y( :PNP4 ), Y( :PNP3 ), Y( :PNP2 ), Y( :PNP1 )),
	//Page(:ColumCategory)
	Elements( Position( 1, 1 ), Box Plot( X, Y, Legend( 14 ) ) ),
	Elements( Position( 1, 2 ), Box Plot( X, Y, Legend( 12 ) ) ),
	Elements( Position( 1, 3 ), Box Plot( X, Y, Legend( 11 ) ) ),
	Elements( Position( 1, 4 ), Box Plot( X, Y, Legend( 9 ) ) ),
	Elements( Position( 1, 5 ), Box Plot( X, Y, Legend( 10 ) ) ),
19 REPLIES 19
Re: Can columns be plotted in graph builder be separated by PAGE using a column name categories?
Page is used for row based grouping, so it cannot be used for what you want to do. You could have a list of columns per each group, then loop over that list while appending separate graph builders to a new window with V List box for example.
Level XIII
Even reformatting the data table doesn't help - the individual Y groups show all items:
If it's just about splitting the column subgroups, you could use a Data Filter instead of Page:
clear log ();
dtstacked = dt << Stack(
	columns(
		:NPN1, :PNP1, :PNP2, :NPN2, :PNP3, :IVP1, :PNP4, :NPN3, :IVP2, :NPN4, :SIT1,
		:INM1, :INM2, :VPM1, :VPM2, :VPM3
	Source Label Column( "Label" ),
	Stacked Data Column( "Data" ),
	"Non-stacked columns"n( Keep( :lot_id, :wafer, :Wafer ID in lot ID, :SITE ) )
dtstacked << new column("first_Label",  Formula( Left( :Label, 1 ) ));
dtstacked <<  Graph Builder(
	Size( 571, 449 ),
	Fit to Window,
	Variables(
		X( :lot_id ),
		Y( :Data ),
		Page( :first_Label ),
		Group Y( :Label ),
		Color( :Label )
	Elements( Box Plot( X, Y, Legend( 16 ) ) ),
	Local Data Filter(
		Add Filter(
			columns( :first_Label ),
			Where( :first_Label == "N" ),
			Display( :first_Label, N Items( 5 ) )
Neo
Neo
@hogi @jthi OK. Thanks. An alternate idea would be to place/send the first graph builder window with a set of columns plotted to a journal window, the next set of new columns plotted under the first and so on and then close open graph windows and associated data tables. How to do this via JSL?
Create list of lists which contain the columns you are interested in and loop over that while building graph builders and appending them to journal / v list box. Are all your columns same in size or does the amount of Y-axis change?
Here is one option, but this isn't the only one you could use
create_graph = Function({dt, ycollist}, {Default Local},
	vlb = V List Box(
		gb = dt << Graph Builder(Variables(X(:lot_id)))
	For Each({colname, idx}, ycollist,
		gb << Add Variable({Eval(colname), Role("Y")});
		gb << Add Element(1, idx, {Type("Box Plot"), X, Y}); // define boxplots
		gb << Remove Element(1, idx, 1); // remove points
	return(vlb);
my_groups = {{"PNP1", "PNP2", "PNP3"}, {"NPN3", "NPN2", "NPN1", "NPN4"}};
dt = Open("$SAMPLE_DATA\semiconductor capability.jmp");
// could also just create journal and add new_vlb to that
nw = New Window("Collector",
	vlb = V List Box()
For Each({my_group}, my_groups,
	new_vlb = create_graph(dt, my_group);
	vlb << Append(new_vlb);
nw << journal;
nw << Close Window;
my_j = Current Journal();
Write();
Neo
Neo
@jthi Number of columns plotted on y-axis will be different for each case/group.
If you have different columns for each case/group, you will need to add the JSL to change the value of "my_group" for each change.
You probably can do that by adding an additional For Each() outside of the current For Each( {my_group), where you change the value of my_group before entering back into the current For Each().
I suggest that you give that a try, and if you run into more issues to come back to the Community with more questions.
Neo
Neo
@jthi @txnelson Thanks.
My parameters to plot is grouped as in the following table. The aim is to append each group below the other in the journal. Also, I would like the group entry to be the chart title for each.  How to modify the above JSL in this case?
In your case I would then use associative array in which the key would be group name and values would be list of parameters (columns). Then loop over this associative array using For Each while building your journal
