jadeyan
Can JMP data table be updated with new input from same excel file
Can JMP data table be updated from same excel file with new input only
Re: Can JMP data table be updated with new input from same excel file
I have simple excel file
imported to JMP
When new lines get added
I can use Update Table table script to update the data. It might be that JMP loads all the data and then updates the corresponding columns
Depending on how your data gets updated, you could also create a Workflow to handle the updates
Level XIII
please note that any processing steps (new columns, formatting, grouping)  will be deleted during the "update".
For "new columns", there is a warning - the other settings get deleted without a warning.
there are several posts in the wish list to optimize the behavior.
Join, Concat and Update
universal "update" button for imported data
Please support them if you need functionality beyond what is possible at the moment in JMP.
