Shunee
Can I set the random seed for random uniform function?
I try to generate a constant random number everytime I run the script. Is there anyway to do that?
ian_jmp
Level X
Re: Can I set the random seed for random uniform function?
Take a look at 'RandomReset()':
nr = 10;
nc = 10;
mat = J(nr, nc, .);
for (c=1, c<=nc, c++,
	Random Reset( 1 );
	mat[0,c] = J(nr, 1, RandomUniform());
dt1 = AsTable(mat);
dt1 << setName("Columns the same");
	Random Reset( 666 );
dt2 = AsTable(mat);
dt2 << setName("Columns the same");
ian_jmp
Level X
nr = 10;
nc = 10;
mat = J(nr, nc, .);
	Random Reset( 1 );
dt1 = AsTable(mat);
dt2 = AsTable(mat);
Shunee
Thank you! Random Reset() work.
