Calculating confidence interval of RSD% with confidence level of 95%
Anyone knows how to calculate confidence interval of RSD% with confidence level of 95%?
I have data set with 6-12 datapoints. I would like to calculate confidence interval of RSD% to investigate the distributions over time.
Thanks in advance,
Gholamhasan Teymoori
MRB3855
Re: Calculating confidence interval of RSD% with confidence level of 95%
Hi @ghteymoori1362 : Here ya go. CV is Coefficient of Variation which is Sigma/mean. Just multiply by 100 to get % RSD.
https://community.jmp.com/t5/JMP-Scripts/Confidence-Interval-for-the-Coefficient-of-Variation-CV/ta-...
Edit: Appears it already multiplies by 100 so no need to do that. You can verify this via the mean and SD.
