Calculating Quantiles for a newbie
To be honest I have never taken a statistics class and for the most part fail at math. I have a set of data that represents cycle time for several stages of an order and I was asked to find the weighted average which wasn't really a problem and I was able to do this inside of SQL. Then I wass told that it was great but they also wanted 80th and 95th percentiles for the orders. After looking confused for a few moments I asked them if they knew how to calculate it, what it meant, or if they had anyone else pull this before. The answer I received was "No but use JMP, we were told it could do it." Ok no problem, contacted IT found we have a license agreement, installed it, then I got to stare at it blankly for a few hours and trying to plug in a few numbers figured out that I have no idea what I am doing. I started looking for guides online but they all seem to assume a certain level of knowledge in mathmatics or JMP in general that I just do not posses. So hopefully someone can help.
The data I have looks similar to this:
Order OE-IP(x) Order IP - SHP(y) Order SHP - POD(z) Total orders(T)
5 ----------------------------- 2 -------------------------- 3 ------------------- 110
3 ----------------------------- 1 -------------------------- 7------------------- 2000
0 ----------------------------- 5 -------------------------- 4 ------------------- 200
There are about 800k lines of data like this so I won't post that up.
How would I use JMP to get the percentiles they are looking for?
For the weighted average I did
[(x+y+z)*T]=C for each line
(Sum of column C / Sum of column T) = Weighted Average
Any help would be greatly appreciated.
dkw
dkw
Re: Calculating Quantiles for a newbie
In JMP the quantiles are specified in the Tables/Summary/ panel. You select the variable for which you want the quantiles and modify the quantiles percentage which is set by default to 25 and then choose Quantiles from the Statistics puldown menu. Grouping can also be set in the obvious manner.
David
Looks like you don't need Jmp.
Here is how you calculate percentiles in SQL:
Suppose you have _Table_ that contains several groups with [Group_ID] of the values and you need to calculate 5th and 95th percentiles for these groups.
------ 5th percentile --------
SELECT MAX ()
FROM (SELECT top 5 percent , [Group_ID]
FROM _Table_
ORDER BY asc)
GROUP BY [Group_ID]
-------- 95th percentile -------
SELECT MAX ()
FROM _Table_
ORDER BY desc)
GROUP BY [Group_ID]
If you still want to use Jmp, then go to Analyze ->"Fit Y by X', choose as "Y,response", [Group_ID] as "X,Factor", press OK. Then click on a red triangle in the popped-up window and select Quantiles.
This can be easily found in Jmp help, btw...
Thanks,
MikeK.
Correction for the 95th quantile:
SELECT MIN ()
FROM _Table_
ORDER BY desc)
GROUP BY [Group_ID]
Sorry,
MikeK.
dkw
dkw
David
Tabulate is an easier place to look for quantile percentage. You drag the analysis variable(s) to the drop space for columns, drag the quantile statistic on top of Sum (the default) and type in the specific quantile). You can drag grouping variables to the left of the quantiles.
