kluu
Calculate difference between 2 group
Hi Everyone,
I am new with jmp.  I have a data table like the below:
index Team value
1        a        5
2        a        12
3        a        20
4        b        5
5        b        22
6        b        6
I want to create a new column, "delta", that calculate the differences between the index group by "team", so i would have something like this:
index Team value delta
1        a        5        .
2        a        12      .
3        a        20      .
4        b        5        0
5        b        22      -10
6        b        6        14
Could you help with the jsl column formula?
Thanks
Khanh
Re: Calculate difference between 2 group
Here is a formula that works for your example table.
If( Row() == 1,
	startTeam = :Team;
	theList = {};
	theDelta = .;
If( :Team == startTeam,
	Insert Into( theList, :value ),
	If( :Team != Lag( :Team ),
		count = 0
	count++;
	theDelta = theList[count] - :value;
theDelta;
If( Row() == 1,
	startTeam = :Team;
	theList = {};
	theDelta = .;
		count = 0
	count++;
theDelta;
kluu
Thank you Jim.  It works
