jc510_2
Bring Window To Front not working properly?
[JMP 17.0.0]
This may be kind of obscure, but let's say I create a new project that contains two data tables: Table 1 and Table 2.  In Table 1, I have a script to duplicate Table 2 in a new Table 3 (if Table 3 doesn't already exist), then bring the focus back to Table 2:
dt = Data Table( "Table 2");
If( Try( Data Table("Table 3") << Get Name, "") == "",
	dt << Subset(
		Output Table( "Table 3" ),
		All rows,
		Selected columns only( 0 )
Window( "Table 2") << Bring Window To Front;
After the script runs, this should change the window focus to Table 2, but instead the focus is on Table 3.  Subsequently running the script brings the focus to Table 2 as intended.
Not sure what I'm missing.
Joel
mmarchandTSI
Level V
Re: Bring Window To Front not working properly?
This is one of those scenarios which call for the Wait() function.
	dt << Subset(
		All rows,
	Wait(0)
mmarchandTSI
Level V
	dt << Subset(
		All rows,
	Wait(0)
jc510_2
Yes - that is exactly it.  This is the first time I've run across a need for the Wait function.
Thank you!
