FN
FN
Bootstrap visualization
I would like to illustrate the concepts behind bootstrap for model fitting.
The following post shows excellent examples
https://community.jmp.com/t5/JMP-Blog/Visualizing-the-variability-of-a-curve-using-bootstrapping/ba-...
Can we reproduce these visualizations without scripting in JMP 16?
I know JMP Pro can bootstrap table parameters, but if I wanted to visualize the predictions of several partition or NN models, I only know how to do this manually.
  1. Sub or resample
  2. Fit
  3. Save prediction formula
  4. Repeat n times
  5. Visualize predictions
ih
Super User (Alumni) ih
Re: Bootstrap visualization
I do not know of a way to draw the different curves without a script, but I frequently look at the distribution of bootstrapped parameter estimates.  You can get to those easy enough by right clicking in the parameter estimates table from any platform and select bootstrap.  A new table will open which you can analyze with the distribution platform to see the range of fitted parameters.
