See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Bar chart
Ted
Ted
Here is the data structure (Test.jmp) and result picture from the platform "Fit Y by X" (Test.jpg). JMP 14
I would like to get the same picture, but with the SEPARATION bars (statistical analysis does not interest).
Re: Bar chart
So, like this (made with Graph Builder):
I left all of the options on so that you can see how this was created. Day on the X-axis. Grades went into an overlay. Number goes into the Frequency role. Used the bar chart graphing element. Bar style is stacked with % of factor as the summary statistic.
Dan Obermiller
Re: Bar chart
Dan Obermiller
Ted
Ted
Re: Bar chart
Thank You! How to get the Y-axis exactly like yours? I have not  "% factor" (only "% Total")
Re: Bar chart
I'm sorry. The % of Factor is a version 15 feature. I forgot that it is not available in version 14. So, to get this in version 14, you will need to add a column to your data table with this formula:
:Number / Col Sum( :Number, :Day )
You will then use this new column as the Y-variable. If you choose the Percent format for this column, the bar chart should look like you want.
Dan Obermiller
