rwridle
Axis labels for hidden and excluded data
When I hide and exclude data in a table and generate a chart, the labels for the hidden end excluded data still appear on the axis. How do I remove the labels for the hidden and excluded data from the chart?
Thierry_S
Re: Axis labels for hidden and excluded data
Could you post an image, or even better the data file and graph, showing what your problem is? It is rather difficult to provide a solution without more details.
Best regards,
TS
Thierry R. Sornasse
rwridle
Thanks for the quick reply!
Attached is an example file from the JMP data directory that demonstrates the question.
I hid and excluded some rows and generated a IR chart. The x-axis labels for the hidden and excluded rows still appear on the chart.
If you are using Control Chart Builder, the following blog post details how to remove the axis labels.  https://community.jmp.com/t5/JMPer-Cable/Removing-white-space-from-control-charts/ba-p/235740
