Thank you for requesting clarification.
What I meant is the I cannot recode all the records involving "John Doe" or "Jane Doe" because most of them should not be changed.
John Doe's name is spelled correct and doesn't need to be changed.
John Doe is a correctly listed as a contributor and a reviewer on other reports.
I cannot recode all the records for "Contributor" task because most of those are correct.
I cannot recode all the records for a specific report because most rows will be correct.
I need to change a specific cell, such as report #123456 for John Doe from Contributor to Reviewer.
It is basically a Venn diagram problem. I can select the rows that need changes but I don't know how to change the value in a specific column for the selected row(s).
Does that make it clearer?
