Automatic AIC calculation from Fit Model?
The AIC and AICc is becoming more standard of a model fitting statistic, yet JMP doesn't implement this except in the Stepwise section of the Fit Model (which doesn't allow the calculation of the AIC with random effects).
Does anyone have a script for calculating this from the regular output of a mixed-effects model in the Fit Model platform? I have been copying the RMSE from the Summary and calculating it by hand once I get the RSS. Is there an automated way of doing this?
Thanks!
Jeff_Perkinson
Re: Automatic AIC calculation from Fit Model?
The AICc is available for most models in the Fit Model platform in JMP 9.
-Jeff
prestom
Hi FlyPod2,
Did you ever find anything that would provide AICc values in the Fit Model platfrom on JMP? If so, would please share it?
Thanks!
Jeff_Perkinson
-Jeff
