dozyme
Automate saving of prediction formula using JMP script?
Greetings all,
Hoping that someone with more JMP script-writing experience can offer some suggestions here.  What I'd like to do is fit a simple linear regression using the "Fit Model" option, then save the prediction formula for the subsequent model to my current data table automatically through the script.  I've been able to do the first part (fit the model), but the second part is proving difficult to figure out.
Any advice would be much appreciated. I'm more familiar with programming in R or STATA, so it's been a process getting used to JSL.  Actually, if there are any recommendations for good JSL references (other than the JMP scripting guide, which I find incredibly lacking), that would also be fantastic.
Dan
10 REPLIES 10
JPKO
Re: Automate saving of prediction formula using JMP script?
Makes sense, thank you so much!
