MathStatChem
Atuomate assigning columns to groups
I've been struggling to figure this out.  I have a table (Table1) that has columns that I want grouped.  Table2 has the column names and group labels I want to use.  I want to script and automate creating the grouped table, as shown in the screenshot below.  Any suggestions on how to do this would be appreciated.
here are scripts to create Table1 and Table2 shown above
dt1 = New Table( "Table1",
	Add Rows( 3 ),
	New Column( "A", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [35, 10, 88] ) ),
	New Column( "B", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [2, 3, 2] ) ),
	New Column( "C", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [1, 3, 1] ) ),
	New Column( "D", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [2, 2, 2] ) )
dt2 = New Table( "Table2",
	Add Rows( 4 ),
	New Column( "Name", Character, "Nominal", Set Values( {"A", "B", "C", "D"} ) ),
	New Column( "GroupName", Character, "Nominal", Set Values( {"G1", "G1", "G2", "G2"} ) )
Re: Atuomate assigning columns to groups
Here is one way to handle the issue:
	Add Rows( 3 ),
	Add Rows( 4 ),
GroupNames = Associative Array( dt2:GroupName ) << get keys;
For Each( {theGroup}, GroupNames,
	// Create a list for a group
	theRows = dt2 << get rows where( :GroupName == theGroup );
	grpList = {};
	For Each( {rowValue}, theRows, Insert Into( grpList, dt2:Name[rowValue] ) );
	dt1 << Group Columns( theGroup, grpList );
I use almost the same idea as Jim, but I like separating the group collection and creation into their own loops
dt1 = New Table("Table1",
	Add Rows(3),
	New Column("A", Numeric, "Continuous", Format("Best", 12), Set Values([35, 10, 88])),
	New Column("B", Numeric, "Continuous", Format("Best", 12), Set Values([2, 3, 2])),
	New Column("C", Numeric, "Continuous", Format("Best", 12), Set Values([1, 3, 1])),
	New Column("D", Numeric, "Continuous", Format("Best", 12), Set Values([2, 2, 2]))
dt2 = New Table("Table2",
	Add Rows(4),
	New Column("Name", Character, "Nominal", Set Values({"A", "B", "C", "D"})),
	New Column("GroupName", Character, "Nominal", Set Values({"G1", "G1", "G2", "G2"}))
aa_groups = Associative Array(Column(dt2, "GroupName"));
For Each({key}, aa_groups << get keys,
	aa_groups[key] = dt2 << Get Rows Where(:GroupName == key);
For Each({{name, cols}}, aa_groups,
	dt1 << Group Columns(name, cols);
	Add Rows( 3 ),
	Add Rows( 4 ),
	grpList = {};
	Add Rows(3),
	Add Rows(4),
