TimeTortoise
Assigning values to new column based on 3 exsisting columns that are a result of a binning formula
Hi JMP Community,
I am trying to find a clean way to assign a value to a column based on values of 3 columns which have been created using JMP's binning formula. Specifically, my team has found that 3 raw material metrics influence how our process runs best (the first one grouped into 4 categories & the other two grouped into 2 categories, giving a total of 16 categories). We would like to mine our historical process data and assign a Bin it. Any suggestions on what tool might be able to help do this?
Attached is a snip showing how our bin's are structured.
Best -TimeTortise
Re: Assigning values to new column based on 3 exsisting columns that are a result of a binning formula
I didn't test this formula for your final bin column, but it should work
As Constant(
	combos = {"HighHighHigh", "HighHigBaseline", "HighBaselineHigh", "HighBaselineBaseline",
	"ElevatedHighHigh", "ElevatedHigBaseline", "ElevatedBaselineHigh", "ElevatedBaselineBaseline",
	"BaselineHighHigh", "BaselineHigBaseline", "BaselineBaselineHigh", "BaselineBaselineBaseline",
	"UnknownHighHigh", "UnknownHigBaseline", "UnknownBaselineHigh", "UnknownBaselineBaseline"};
	binList = "ABCDEFGHIJKLMNOP";
"Bin " || Substr( binList, Contains( combos, :Moisture || :Mw || :LOI ), 1 );
For which column are you looking the values for? And what do you consider "clean"? If it is a Bin column you could: concatenate all the three columns together to create a new column. Then map that to bin values using Match() in a formula or by using Value Codes column property. You could also just create mapping table and use Join/Update to add the binning values
As Constant(
TimeTortoise
Jim,
Thanks that is a very clever use of those two functions! I will need to rewrite for my table but it is more than enough to get me on the right path. I would never have thought of such an elegant solution.
Best -Ben
