Jackie_
Assigning Minimum value to a column
Hi folks,
I have 2 files.
1st file:
2nd file :
I am trying to write a script which will search for the Minimum age from the 1st file and assign the lowest age in the 2nd file
For e.g.
The 1st row which has three name Sam, John, Smith so the Value in the Minimum Age Column should be Min{Sam, John, Smith}  Min{21, 27, 32} = 21
my final output will look something like this:
Any suggestions please?
Thanks
13 REPLIES 13
Re: Assigning Minimum value to a column
Here is one of the examples I gave
Column( "Age" ) << Get Property( "Units" );
If you examine the documentation on the Column() function in the JSL Syntax Reference, it reads
Column(<dt>, "name", "formatted")
Column(<dt>, n)
	Description
		Gets a reference to the data table column.
	Arguments
		dt Optional reference to a data table. If this is not supplied, the current data table is used.
		name Quoted string that is the name of the column.
		formatted Quoted string that returns the formatted string of the cell value.
		n Column number.
IF you read the example from the Syntax Guide it reads:
The Column function can also identify a column. For Big Class.jmp, the following expressions
all refer to age, the second column in the table:
	Column( "age" );
	Column( 2 );
	Column( dt, 2 );
	Column( dt, "age" );
Jackie_
I mean in this script replacing Column name with Column Index
dt1 = Data Table( "1st" );
dt2 = Data Table( "2nd file" );
Current Data Table( dt1 );
For( i = 1, i <= N Rows( dt2 ), i++,
	dt2:Minimum Age[i] = Col Min( If( Contains( dt2:Name[i], dt1:Name ), dt1:age, . ) )
Jackie_
Hi @txnelson,
I tried to replace column name with column index but it's not running
Any suggestions?
Names default to here(1);
dt1=data table("1st");
dt2=data table("2nd file");
current data table(dt1);
For(i=1,i<=nrows(dt2), i++,
	dt2:Column(2)[i] =col min(If(contains(dt2:Column(1)[i],dt1:Column(1)),dt1:Column(2),.));
The Column() function is not
d2:Column(2)[I]
it is as stated
Column( dt, 2 )[I]
And if the indexes were variables,  the completed script would be
indexd2minage = 2;
indexd2name = 1;
indexd1name = 1;
indexd1age = 2;
	Column( dt2, indexd2minage )[i] =
	Col Min(
		If(
			Contains(
				Column( dt2, indexd2Name )[i],
				as Column( dt1, indexd1Name )
			Column( dt1, indexd1age ),
