BookmarkSubscribeRSS Feed
Hegedus
Community Trekker
Jun 23, 2011
Arrange in rows by group
Here is the problem I am trying to solve:
6 Y continuous variables (Y1,Y2,..Y6), same continuous X variable (1) and sample ID field (SID).
I am doing a BiVariate fit grouping by SID. I would like all 6 plots to be in a row and with each SID group.
SID=1
Y1,Y2,Y3,Y4,Y5,Y6,
SID=2
Y1,Y2,Y3,Y4,Y5,Y6,
How would I script this?  The Y's and X are know and fixed while the number of sample IDs will vary.
Andy
3 ACCEPTED SOLUTIONS
Jun 22, 2012
Solution
Re: Arrange in rows by group
Here is an example script using a methodlogy I have used many times, that I think produces the results you want.
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
// Setup data to look somewhat like your data
dt << delete columns( 1, 2, 3 );
Column( dt, 1 ) << set name( "SID" );
Column( dt, 2 ) << set name( "X" );
Column( dt, 3 ) << set name( "Y1" );
Column( dt, 4 ) << set name( "Y2" );
Column( dt, 5 ) << set name( "Y3" );
Column( dt, 6 ) << set name( "Y4" );
Column( dt, 7 ) << set name( "Y5" );
Column( dt, 8 ) << set name( "Y6" );
dt << delete columns( Index( 9, 129 ) );
// Determine the number of SIDs
Summarize( dt, SIDgrps = by( SID ) );
// Create the output window
nw = New Window( "Report", MainVLB = V List Box() );
// Create a list to hold the data table names
dtList = {};
// Setup what to do when the display window is closed
nw << on close( For( i = 1, i <= N Items( SIDgrps ), i++, Close( dtList[i], nosave ) ) );
// Loop through the SIDs and generate the required reports
	dt << select where( :SID == Num( SIDgrps[i] ) );
	dtSub = dt << subset( selected rows( 1 ), selected columns( 0 ), invisible );
	Insert Into( dtList, dtSub );
	dtSub << set name( "SID=" || SIDgrps[i] );
	ob = Outline Box( "SID=" || SIDgrps[i],
		H List Box(
			dtSub = Bivariate( Y( :Y1 ), X( :X ) ),
			dtSub = Bivariate( Y( :Y2 ), X( :X ) ),
			dtSub = Bivariate( Y( :Y3 ), X( :X ) ),
			dtSub = Bivariate( Y( :Y4 ), X( :X ) ),
			dtSub = Bivariate( Y( :Y5 ), X( :X ) ),
			dtSub = Bivariate( Y( :Y6 ), X( :X ) ),
	// Add the current set of reports to the main display
	MainVLB << append( ob );
markbailey
Jun 23, 2011
Solution
From your description, it seems like all you have to do is use SID in the By role.
Bivariate(
	Y( :Y1, :Y2, :Y3, :Y4, :Y5, :Y6 ),
	X( :X ),
	By( :SID )
markbailey
Jun 23, 2011
Solution
I think this way might be simpler and give you the layout you want:
New Window( "Fitness - Bivariate",
	V List Box(
		Fit Group(
			Bivariate( Y( :Age ), X( :MaxPulse ) ),
			Bivariate( Y( :Weight ), X( :MaxPulse ) ),
			Bivariate( Y( :Oxy ), X( :MaxPulse ) ),
			Bivariate( Y( :Runtime ), X( :MaxPulse ) ),
			Bivariate( Y( :RunPulse ), X( :MaxPulse ) ),
			Bivariate( Y( :RstPulse ), X( :MaxPulse ) ),
			<<{Arrange in Rows( 2 )},
			By( :Sex )
		Fit Group(
			By( :Sex )
Jun 22, 2012
Solution
dtList = {};
		H List Box(
markbailey
Jun 23, 2011
Solution
Bivariate(
	X( :X ),
	By( :SID )
Hegedus
Community Trekker
Jun 23, 2011
The code from txnelson does the job,  Though in his example I needed comment out the code line
//dt << delete columns( Index( 9, 129 ) ); for it to run.
I must admit, I don't fully understand it and I stumbled a bit with this line
dt << select where( :SID == Num( SIDgrps[i] ) ); since my ID is actually character.  I removed the Num() to get it to work.
Mark's solution only does the by SID grouping but does not group the plots in rows.
Andy
markbailey
Jun 23, 2011
This shows one way to control the layout but the resulting array of plots is the transpose of what you want.
New Window( "In a Row",
	Line Up Box( N Col( 2 ),
		Bivariate(
			Y( :age, :weight, :oxy, :runtime ),
			X( :runpulse ),
			By( :sex )
markbailey
Jun 23, 2011
Solution
	V List Box(
		Fit Group(
			By( :Sex )
		Fit Group(
			By( :Sex )
