abdulj
Arrange Grid in Graph Builder Manually
Hi
I produce a couple of graphs using graph builder and also use the "Wrap" function to organize my data in a grid. Currently the grid is arranged alphabetically, is there a way for me to arrange it manually??
thanks
mfisher
In the data table, click the column you want ordered, then right-click, select "column properties" then "value ordering".  You can then put them in any order you wish.
Mark
mfisher
Mark
