lala
Level IX
Are there any other ways to create a new script in the JMP table?
I think it will have /*...*/ The content of cannot be written
For example, the script is like this
Include("C:\gr.jsl");
dz=Open("C:\gr.jsl",Charset("gb2312"),Add to Recent Files(0));
I use
dt=Open("$SAMPLE_DATA/Big Class.jmp");
Eval(Parse("dt<<new script(\!"test\!", Include(\!"C:\gr.jsl\!");   );"))Thanks Experts!
Re: Are there any other ways to create a new script in the JMP table?
dt = open("$SAMPLE_DATA/Big Class.jmp");
dt << New Script("A",
JSL Quote(Include("C:\gr.jsl");
As String(1)
Which script are you trying to create? Do you wish to keep the comments? How to automatically write code containing /**/ to JSL? ?
lala
Level IX
no word
I'm still not sure what you are trying to achieve here
lala
Level IX
I need to directly generate the content of such a script in the table using a script.
Thanks Experts!
As String(1)
Level XIII
Hi @jthi , do you remember where you found the as string (1) option.
super helpful! should be added to the scripting index - or made easier to finde if it is already there ...
From script JMP creates when you use "Copy Table Script"
