vgiacalone
Applying quantiles and wilcox test to all graphs
Hello, I am a new JMP 15 user and need help with what is probably an easy task. I successfully imported my excel database and created a sheet with many graphs by doing Fit Y by X. I can click on the red arrow next to OneWay Analysis for each graph to enable the quantiles and Wilcoxon each pair, but there must be a way to quickly apply this to all graphs rather than click one at a time. Any help will be appreciated. Thank you
ih
Super User (Alumni) ih
Re: Applying quantiles and wilcox test to all graphs
Hold down control while you click on the red arrow, then let go of control and select the option. That will 'broadcast' the command to similar items in the platform. This works other places too, like distributions.
Hint: also try holding Alt, or Control and Alt.
ih
vgiacalone
thanks, worked great!
