HubP_SDe
Application Current DataTable
Dear Community,
With your help, and many searches and iterations, I'm now close to wrapping-up my first JMP application.
I'm still struggling on few points, for which sure someone will suggest easy solutions ;):
  1. A the end of Dialog1 script, I'm opening a Data Table that was selected by the User
    • OnNext1 = Function( {},
      	file_path = FilePath << GetText();
      	If ( file_path != "",
      		//IST Text File
      		dt = Open(
      			file_path,
      			Columns(...)
      		CurrentDataTable( dt );
      		Dialog2 << CreateInstance( dt );
    • But I'd never get the CurrentDataTable correctly set when reaching Dialog2
    • Can be seen after filling the File Path field and pressing "Next":
      Dialog2 Tiltle = ^APPNAME - ^TABLENAME
      shows no Table Name, or another preloaded DataTable name :(
  2. This next issue would supposedly be fixed by the previous one:
    • A the end of Dialog2 script, I'm willing to Append all Columns starting with a given string, to the Dialog2 Col List Box.
    • It currently remains deperately empty, certainly due to issue #1
    • Plus getting following errors:
      • Send Expects Scriptable Object 22 times in access or evaluation of 'Send' , ColList1 << /*###*/Background Color( 2147483647 ) /*###*/
        Send Expects Scriptable Object 3 times in access or evaluation of 'Send' , ColList1 << /*###*/Set Data Type( "numeric" ) /*###*/
        Send Expects Scriptable Object in access or evaluation of 'Send' , ColList1 << /*###*/Get Items/*###*/
  3. Whatever happens on Dialog2, if I now press "OK", I'm getting the following error, related to calculated Custom Quantile variables used in Module "Report1":
    • Invalid matrix token.
      Line 69 Column 41: ...les( ( Percent1 /100 ), [►( Percent1 /100 ), ( Perc...
Stéphane DELACROIX
Senior Simulation & Planning Engineer
Craige_Hales
Re: Application Current DataTable
Keep the data table reference in a variable (dt in your example) and always use dt:col (etc) to reference a column. Don't depend on the current data table; the current data table changes when the user clicks any table, and possibly when any new window opens.
The error "Send Expects Scriptable Object" could explain itself better. @Audrey_Shull . The << operator is the send operator. The left hand side should be an object and the right hand side a message for the object to process.
myobject << message( ... );
The error means the left hand side is not an object that accepts messages (a scriptable object). "myobject" isn't what you expect. Try
show(myobject);
or
show(type(myobject));
to get some idea what is going on.
Craige
HubP_SDe
Thanks Mark,
  1. If you take a closer look at the end of "Dialog1" script, you'll see that I'm passing the "dt" reference to "Dialog2", which I'm then using in the code explicitly.
    • Neither this, not the CurrentDataTable command, seem to populate the "^TABLENAME" global reference in the "Dialog2" Title field.
    • I tried "^APPNAME - ^dt", but "^dt" is then displayed as a raw string
    • I also tried to add "TABLENAME = dt;" in "Dialog2" "OnModuleLoad", but nothing changes in Dialog2 windows title: TABLENAME remains empty
  2. Dealing with the "scripting object" error, I suspect it is related to the ColList object of "Dialog2" apparently being null a the Table is not yet open at app launch.
    • I suppose I'll have to create the Col List Box dynamically in script to work this around.
Cheers!
Stéphane DELACROIX
