FlorenceJMP
Aplatir une table
Bonjour,
Est il possible dans JMP de joindre plusieurs colonnes en 1 seule ligne à partir d'un identifiant, autrement dit: passer du premier tableau au second?
Merci
NOMPrénomitem 1item 2item 3item 4
frzegfzefezA12224a
fezfezB35b
fezfezC467c
GRZGRxcsqD55d
GZEGFEZE231e
GZEGFEZF72f
GZEQDG80g
NOMPrénomitem 1-1item 2-1item 3-1item 4-1item 1-2item 2-2item 3-2item 4-2item 1-3item 2-3item 3-3item 4-3
frzegfzefezA12224a
fezfezB35bC467c
GRZGRxcsqD55d
GZEGFEZE231eF72fG80g
GZEQDG80g
hogi
Level XIII
Re: Aplatir une table
in the second table, "G" shows up twice. with GFEZ and QD?
hogi
Level XIII
You could stack and then split the data.
To stack the columns, they have to have the same format. So maybe some additional step are necessary to align the formats and set them back to the original format.
dt = New Table( "demo",
	Add Rows( 7 ),
	Compress File When Saved( 1 ),
	New Column( "NAME",
		Character,
		Set Values( {"frzegfze", "he did", "he did", "GRZGR", "GZE", "GZE", "GZE"} )
	New Column( "First name",
		Character,
		Set Values( {"he did", "he did", "he did", "xcsq", "GFEZ", "GFEZ", "QD"} )
	New Column( "item 1",
		Character,
		Set Values( {"A", "B", "C", "D", "E", "F", "G"} )
	New Column( "item 2",
		Character,
		Set Values( {"12", "3", "4", "5", "2", "7", "8"} )
	New Column( "item 3",
		Character,
		Set Values( {"224", "5", "67", "5", "31", "2", "0"} )
	New Column( "item 4",
		Character,
		Set Values( {"a", "b", "c", "d", "e", "f", "g"} )
dt << New Column( "entry",
	Formula( Col Rank( Row(), :NAME, :First name ) ),
dtstacked = dt << Stack(
	columns( :item 1, :item 2, :item 3, :item 4 )
dtsplit = dtstacked <<
Split(
	Split By( :entry, :Label ),
	Split( :Data ),
	Group( :NAME, :First name )
