  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
Analysis of Data Using Mean and SD
I wanted to know if there is a way to run models and perform data analysis when the data is only available as means and standard deviations. While modeling generally uses the mean and standard deviation as metrics to analyze and model data, JMP calculates them and then uses them for your chosen method. Unfortunately, my partners only have the data available as the means and SD per formulation. Thank you very much, and have a great day. I appreciate your time and expertise.
statman
Re: Analysis of Data Using Mean and SD
I'm sorry if I don't understand your question.  I think it is appropriate to look at the raw data before summarizing and describing the raw data with enumerative statistics (e.g., mean and standard deviation).  Are those the appropriate statistics to use?  Once you have the summary statistics, you can certainly model them.  I would first look to see if they correlate, then run separate fit models to asses model effects.
Potcner
Yes, you can do the analysis on the means and std devs very similarly if you had the raw data. In your example, however, 'Formulation' isn't a possible factor to use as that's just an ID for each set of data values. You would just want to use 'Percent'. That's a factor that has 3 levels with 2 values at 0, 3 at 12.71, and 4 at 30.
If you have 'Percent' as a categorical variable, than the Fit Y by X platform would result in doing ANOVAs. Note: Some people like to use Log(SD) as the response instead of just the SD, as that transforms the values so they're more normally distributed. Not necessarily though unless you're trying to some very precise inference. You're probably fine as is.
If you have 'Percent' as a continuous variable, than the Fit Y by X platform will fit a linear regression.
Just make sure when interpreting results you do so knowing the data analyzed are the means and std deviations and not individual data values for whatever attribute was measured. A nice graph to do with this kind of data is to plot the means on one axis, the std dev on the other, and then use a symbol or color to show the 3 % levels. This allows you to simultaneously view the central tendency and variation for each of the 3 % levels.
I attached .jmp file with the analyses and graphs.
