  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
ojori
All dialog box controls are unresponsive
Please watch the video.
Clicking on a control in a dialog box is not reflected on the screen.
This problem occurs with all lists, pull-downs, tree lists, etc.
However, if you change the size of the dialog box, it will be reflected.
I have tried both JMP Pro 16 and Pro 17 and this happens in all dialog boxes.
My PC is LG gram with Win10 having screen size of 2560 x 1600 x 150% (recommended setting), but setting it to 100% does not fix it.
https://youtu.be/963SooVBOeo
Uploaded by リスクとスリル on 2023-01-21.
Thierry_S
Re: All dialog box controls are unresponsive
This problem is similar to an issue with video-card hardware acceleration. Have you tried to turn off the "Enable Hardware Acceleration" option in the Preferences > Windows Specific
Best,
TS
Thierry R. Sornasse
Thierry_S
Best,
TS
Thierry R. Sornasse
ojori
It was a brilliant solution. Thanks a lot.
