Xinjie
Alert in model extrapolation control feature
In the extrapolation control feature available in JMP 16 Pro, I've had several cases where the profiler contains feasible ranges when extrapolation control is turned on, but when I clicked "Output Random Table", the alert "Unable to find any random feasible points" appears. How to fix this problem? Thanks!
Phil_Kay
Re: Alert in model extrapolation control feature
Can you attach an example that you are able to share with the community?
Thanks,
Phil
