lala
Level IX
After generating a new script in a data table through JSL, why does the operation behind the original JSL stop?
For example the following JSL
Does it finish adding scripts and then stop working?
Eval(
	Parse(
		"dt<<new script(\!"test\!",
dt<<Select Columns(ncol(dt));dt<<Move Selected Columns(after(Column(1)));
New Column( "AA" );
Re: After generating a new script in a data table through JSL, why does the operation behind the original JSL stop?
There is a syntax error in the JSL.  The Log shows
Unexpected end of input. Perhaps there is a missing "," or ")".
Trying to parse arguments of function "new script".
Line 2 Column 75: …olumns(after(Column(1)));►
The issue is a missing closing ");) for the New Script() function.  If the closing ");" is added the JSL works as expected.
Eval(Parse(
dt<<Select Columns(ncol(dt));dt<<Move Selected Columns(after(Column(1))););
dt << New Column( "AA" );
lala
Level IX
Eval(Parse(
Thank Jim!
