Zoe_Betteridge
Adding reference lines to a log scale
I'm hoping someone has a solution to my issue. I am using graph builder and adding two continuous variables to the Y axis - both require the same log scale. This works okay with a scale from 0.1 to 1e+10 until I try and add the reference lines. I have lines to add at 475000 and 4750000 - which when I add and look at the preview appear to be fine (see screenshot)
however when I click OK - I get the following plot with lower minimum values that won't change even when I try and edit it.
I have tried adding the axis preferences to the columns in the data table and saving the graph script and editing there but still get the same result. Is there a reason why I can't have the plot starting at 0.1? I can get it two work if I have the two columns as separate graphs but can't get them to overlay.
Thanks Zoe.
ih
Super User (Alumni) ih
Re: Adding reference lines to a log scale
Hi @Zoe_Betteridge,
I cannot seem to replicate your issue.  If you run the script below are you able to adjust those axis limits?
Names default to here(1);
dt = Open("$Sample_data/Big class.jmp");
New Column("Exp[height]", Numeric, "Continuous", Format("Best", 12), Formula(Exp(:height / 20)));
New Column("Exp[weight]", Numeric, "Continuous", Format("Best", 12), Formula(Exp(:weight / 20)));
Graph Builder(
	Size( 763, 619 ),
	Show Control Panel( 0 ),
	Variables(
		X( :name ),
		Y( :"Exp[height]"n ),
		Y( :"Exp[weight]"n, Position( 1 ) )
	Elements( Line( X, Y( 1 ), Y( 2 ), Legend( 4 ) ) ),
		Dispatch(
			"Exp[height]",
			ScaleBox,
			{Scale( "Log" ), Format( "Best", 6 ), Min( 1.07137524526672 ),
			Max( 3564457.95421388 ), Inc( 1 ), Minor Ticks( 0 ),
			Add Ref Line( 100000, "Solid", "Black", "a", 1 ),
			Add Ref Line( 1000000, "Solid", "Black", "b", 1 )}
