njmp
Adding new columns to a data table
i create a table and try add two aolumns in jsl as follows:
Test = New Table( "Test" );
Test << New Column( "Ident", Character, Continuous, Format( "Best", 8 ), set values( identifiers ) );
Test << New Column( "Value", Numeric, Continuous, Format( "Best", 8 ), set values( values ) );
identifiers - is a list of caharacters
values - a a list of matching numbers.
using the format above, creates only ident column , populates with values and stops before adding the second column. no report of an error.
(if i run the command latter manually it adds also Value column and the values.
if i use a slightly different format (below), no issues and both columns are created and populated with the values:
Test=new table("Test");
Test<<new column("Value",Numeric,Continuous,format("Best",8),set values(values));
Test<<new column("Ident",Character,Continuous,format("Best",8),set values(identifiers));
any explanation to this behavior?
Re: Adding new columns to a data table
A column that has is of Data Type, "Character", can only have a Modeling Type of "Nominal".  Also, a Format definition for a Character column can not be specified.  The script below is a modification of your script that runs without error
identifiers = {"a", "b", "c"};
values = {1, 2, 3};
Test <<
	Character,
Test <<
	Numeric,
	Continuous,
values = {1, 2, 3};
Test <<
	Character,
Test <<
	Numeric,
	Continuous,
njmp
Thanks a lot:)
Jackie_
Hi @txnelson,
Thanks for your help.
2nd file doesn't have Minimum Age Column. How can I create the 2nd column with name "Minimum Age" and then run the above script?
