CurbGazelle
Adding connecting letters after Kruskal Wallis and Steel-Dwass post-hoc pairwise testing
Greetings all,
I'm wanting to produce connecting letters (e.g., a, b, c, etc.) to signify statistically significant differences and similarities among pairwise comparisons of groups after Kruskal-Wallis testing and post-hoc Steel-Dwass analysis (non-parametric equivalents of one way ANOVA and Tukey's HSD tests).
These are readily supplied when ANOVAs and student's t-test / Tukey's tests are performed for parametric data (Fig. 1), though not when non-parametric data are analyzed (as is my case).
Figure 1: Connecting letters report from Tukey-Kramer HSD post-hoc analysis after ANOVA
After scouring the internet for how to do this in JMP, as well as in RStudio and others, I have come up empty. Is there any way to have this simple yet informative actioned in JMP??
Thanks in advance
Phil_Kay
Re: Adding connecting letters after Kruskal Wallis and Steel-Dwass post-hoc pairwise testing
I've had a look and it seems there is no built-in option for this. If you like scripting then you could create something yourself to do this. Otherwise I think you will need to add this to the JMP Wish List.
Sorry I don't have a better answer for you.
Phil
Phil_Kay
Phil
Phil_Kay
