fuscod
Adding a Column and Populating with Data
JMP Users I have a simple question I would like to create a new column and populate it with data based upon information in and existing column.  For examples, say I have a column of "Animals" as so:
ANIMAL
CAT
DOG
HUMAN
HORSE
SNAKE
LIZARD
CROCODILE
TURTLE
TURKEY
CHICKEN
EAGLE
DUCK
ANT
BEE
SPIDER
FLY
I WOLD LIKE TO WRITE JSL SCRIPT TO ADD A "CATEGORY" COLUMN AND TO POPULATE THE CATEGORY COLUMN WITH DATAT.  WITH THE RESULTS BEING:
ANIMAL                    CATEGORY
CAT                           MAMMAL
DOG                         MAMMAL
HUMAN                    MAMMAL
HORSE                    MAMMAL
SNAKE                     REPTILE
LIZARD                    REPTILE
CROCODILE           REPTILE
TURTLE                  REPTILE
TURKEY                 BIRD
CHICKEN               BIRD
EAGLE                    BIRD
DUCK                     BIRD
ANT                         INSECT
BEE                        INSECT
SPIDER                  INSECT
FLY                         INSECT
SO IF THE ANIMAL IS A MAMMAL I WANT THE CATEGORY COLUMN TO POPULATE "MAMMAL", IF THE ANIMAL IS A REPTILE I WANT THE CATEGORY COLUMN TO POPULATE "REPTILE", ETC.
Thank you,
Dan F.
Re: Adding a Column and Populating with Data
The easiest way to do this would be to create a lookup data table that has the master set of animals matched with the category;  Then all that has to be done is to Update the data table with the lookup table, specifying to keep all rows in the original table, but only the matching rows from the lookup table.
dt = Data Table( "Data" );
dtud = Data Table( "Lookup" );
Data Table( "Data" ) << Update(
With( Data Table( "Lookup" ) ),
Match Columns( :ANIMAL = :ANIMAL )
Jeff_Perkinson
To do this by hand (without a script) you can use Cols->Utilities->Recode on your original column.
When you click the Done button you'll have the option of creating a Formula Column which will create a new column with a formula that will assign values based on the animal.
Here's a video showing Recode.
-Jeff
-Jeff
